Can SW2007 open the file whose fomat is .stp?
What's wrong with that?
When I open some files,alarm happens as follows:
Microsoft visival C++ Runtime Library
Runtime Error!
Program:C:\Program Fifles\Solidworks\Sldworks.exe
This application has requested the Runtime to terminate it in an anusual way.
Please contact the application's support team for more information.
So,Who knows this? Thanks for help!
Runtime Error!
RE: Can SW2007 open the file whose fomat is .stp?
As far at the error you are getting, I'd contact my reseller. You might also need to reinstall SolidWorks as it's giving you a C++ error.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
http://en.wikipedia.org/wiki/ISO_10303-21
http://en.wikipedia.org/wiki/IGES
http://en.wikipedia.org/wiki/CAD_data_exchange
Cheers,
Anna Wood
SW2008 SP3.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
Dan
www.eltronresearch.com
Can you read that file back in?
Yes, you can Save As to step or iges, plus a bunch of other file formats. Then you can Open them back up in SolidWorks.
Take a look at all the options in the drop downs for file types when opening and saving files in SolidWorks.
You guys need to be adventurous and explore all the options in all the windows that are presented when doing things in SolidWorks. Push all the buttons/tabs and see what they do....
Cheers,
Anna Wood
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
Ahhh.... Yes, you are probably right.
I think huipain may have an install issue. I am thinking I remember some folks talking about this issue over on the SolidWorks forums at www.solidworks.com. A trip through the knowledge base over there may yeild some results.
Would also help if we knew what version and SP the OP is using.
Cheers,
Anna Wood
If it won't there is no point in fooling with the unkown or 3rd party neutral until the problem is solved with the known data.
Certified SolidWorks Professional
Autodesk Inventor Certified Expert
Not too bad with AutoCAD, MDT, Pro/E
RyanC
