Sketching Lines are Solid?
I just put Wildfire 3.0 on my laptop and my sketching lines are solid instead of dashed. The same goes for the x and y lines in the sketching mode. These should be dashed and it is driving me crazy. Anyone have any idea how to fix this?
Thanks, Steve
Thanks, Steve
RE: Sketching Lines are Solid?
show_selected_item_id YES/no*
active/default*
If a line or arc is construction you'll see (Construction) following the ID.
Or you can zoom way in and they'll appear as construction. If you select and Right click you'll see
SOLID option if it's construction or
CONSTRUCTION if it's Solid.
Michael
