Re-igniting burner in high temperature chamber
Dear Readers,
We are looking at using a burner to bring a reactor up to temperature of 650°C and then turning off the burner as the process becomes self sustaining. To reduce down time when a feed shut down occurs, we would like to restart the burner to avoid having to cool the whole system down to air temperature. I have been told that the burner would not be allowed (under regulations) to restart if the temperature in the reactor is under 700°C. Could someone please confirm this temperature and let me know which regulations would mention this limit?
Thank you very much!
RE: Re-igniting burner in high temperature chamber
Thanks for the information. I also looked-up BS EN 746-2 and the requirement there if for 750°C.
Cheers.
