Custom holes in the Hole Wizard?
Is it possible to import a custom hole into the hole wizard?  I have been drawing rather complicated hydraulic cavities then cut-revolving them.  this requires a new plane for each, and lots of line work.
there must be an easier way.
We work on SW 2007
RE: Custom holes in the Hole Wizard?
Create the feature as a Library Feature. You will then be able to drag and drop it onto other parts.
cheers
