How can I remove meat particles and salt from wastewater?
Sorry about the vagueness of my previous post. I am working on the treatment of the wastewater for a salmon smoking facility in upstate New York. The salmon is delivered in fillets so there is no gutting going on or anything like that. The facility currently discharges there wastewater into a ditch witch leads to a nearby small river. I am looking treating the water and continuing to discharge it into the river or into an absorption field similar to a rural residential septic field. I am trying to figure out how to remove whatever fish particles get into the wastewater while washing and also what to do with the salt used for preservation. For the fish meat I am thinking about filtering the water or allowing the pieces to settle out, is this reasonable? And for the salt, I am worried about discharging it into a freshwater river. Any help would be much appreciated.
RE: How can I remove meat particles and salt from wastewater?
It is probably going to be less expensive to keep the materials out of the wastewater stream, then to try to remove the materials from the wastewater.
The selection of wastewater treatment technology is going to depend on the size of the food processing operation, which you have not posted.
Food manufacturing plants usually incorporate some type of DAF unit to remove suspended matter as well as FOG. You can probably install a DAF and then filter the DAF discharge. DAF is the traditional wastewater treatment technique for the food industry.
The DAF unit is probably the least expensive technology.
Removing dissolved salts would require some type of reverse osmosis treatment and will be so ridiculously expensive that your client can not afford to even think about it. Don't even waste your time with the salt removal. Try to keep the salts out of solution. Note that it is very, very rare when there is a TDS limit on the discharge.
