need a pressure drop on discharge side of pump
Hi
i am new to the pump calculations and in my application i have a pump which is discharging water at 100 psi. i want to reduce this pressure to around 60 psi.
what is the best way to do it.
Thanks in advance for your help
RE: need a pressure drop on discharge side of pump
You're probably wasting 40% or more of your pump's power supply. Exact number depends on the pum's efficiency at whatever flowrate you have.
At least ask yourself, "what's the cost of that wasted power over the next 3-5 years or so?"
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
Why do you want to reduce the delivery pressure?
Ted
We need way more info to offer the correct answer.
Seán
http://www.expertise-limited.co.uk/
Ash Fenn
www.cdrpumps.co.uk
