Autoignition temperature or ignition temperature
Hi-
       ASTM standard E 659-78    gives a test method for autoignition temperature of liquid chemicals and says that it can be used for some solids.
       Is there a similar standard for gases ?   Or is the standard assumed to apply for gases as well?
       I did find a reference to a British Standards Institute document for gases:
             BS 4056
        and these might be related:
        DIN 51795  and  IEC 79-4
         I have not found actual copies of BS 4056  or  DIN 51795  and  IEC 79-4.     So if anyone knows of a link to them, please let me know.
Thank you!
RE: Autoignition temperature or ignition temperature
Although I haven't downloaded these, check the following:
API RP 2216, Ignition Risk of Hydrocarbon Liquids and Vapors by Hot Surfaces in the Open Air-Third Edition.
ASTM E 1491, Standard Test Method for Minimum Autoignition Temperature of Dust Clouds.
