Circular Anchor Bolt Patterns (Refferences??)
I have a circular base plate with a circular anchor pattern. I was looking for a reference on Breakout areas for breakout,pullout etc. I have references for square and rectangular anchor patterns but nothing mentioned for circular. Are there any suggestions as where to start??
RE: Circular Anchor Bolt Patterns (Refferences??)
Not sure about your actual situation but this should get you started.
For poles up to 6' diameter, we tend to use a ring plate at the base of the anchor bolts and about 3'-6" down to make these behave as a group. Just remember that half your bolts are in compression if it is in bending.
