surface models in drawings
When i create a drawing, all my belts which are surface models do not show up. Is there any way for surfaces to be visable in drawings?
Matthew
Matthew
RE: surface models in drawings
Then select and copy the object as a solid. Delete the files that are no longer needed
Sometimes it works sometimes it doesnt but worth a try
But to answer your question no you can't set that on a mass document level. Its view by view
thanks
