Inventor 2009 Importing Settings
I have loaded Inventor 2009 now and its gone in alongside 2008
Is there any quick way of importing all my settings over in one hit as it has come in as per straight out the box and has not picked up the settings I was using on 2008
Many thanks
RE: Inventor 2009 Importing Settings
In Inventor 2008 Tools>Application Options>Export and Tools>Customize>Export  (give a unique name and location to the export files so that you can easily find them)
In Inventor 2009 Tools>Application Options>Import and Tools>Customize>Import the files created above.
Thank you for this
A simple thing but saves so much time setting it all up again o try and get it the same
Unfortunatly it does not import all the settings. In a typical lack of joined up thinking it does not seem to import the drawing settings which always seem a pig of a job to set up each time
I haven't tried it but I think you can export through Styles and Standards editor
or
Drawing Resource Transfer Wizard
or
Style Library Manager
