MS OFFICE FILES ON SOLID WORKS PDM
We are using SolidWorks PDM to control our SolidWorks files. It works relatively well.  We use custom fields like REV, DCR, STATUS, DESCRIPTION, etc that are used in the drawing blocks and also as descriptors on PDM.
My question is. . . . If I wanted to also control MS Office files using the PDM Vault (which is possible), how can this be done?
I know how to create custom fields on office documents.  The problem is that I am naming them the same as in the drawings and they don't seem to change when I check the document into the vault.
My goal is to display the status of the document as a watermark, the revision, document number, and the DCR as part of the header.
Anyone?
RE: MS OFFICE FILES ON SOLID WORKS PDM
jfrnandz,
Did you get this solved. We want to do the samething here.
Bradley
SolidWorks Pro 2008 x64, SP3.0
PDMWorks Workgroup, SolidWorks BOM,
Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB,
nVidia Quadro FX 3400
Use SolidWorks BOM
e-mail is Lotus Notes
No answers yet from Solidworks.  Will let all of you know if I have a solution.
A file name isn't 100% the same if the extensions are different.  Try one in your PDM and see what happens.
You should be able to add any type of file to the PDMW. You can also add Office files to the Design Binder in the SolidWorks file.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
You can put any file into PDM Works.
I would like to see SolidWorks Corp put some type of property on the document that would follow the Property in PDM Works.
Bradley
Use SolidWorks BOM
