Heat Gain from Computers
We've been using the same heat gain from computers for quite a while now in our cooling load calculations, despite the fact that computers are running more efficiently and LCD monitors are much cooler than CRT.
Does anyone have a website or resource that lists 'actual' heat gain from computer equipment into a modern office?
RE: Heat Gain from Computers
http:/
An energy-efficient computer brings many important benefits to its owners and users, and to the developers and
owners of the building where it is installed. These benefits include in our example:
· direct electrical savings around 80% during office hours
· additional savings, typically about 35% as big, in air-conditioning energy
· further savings in uninterruptible-power-supply losses and wiring losses, raising the total electricity savings
to the neighborhood of $100 a year (or about $500 present-valued) at average U.S. commercial rates where
a UPS is used (but reliability will be much lower if it isn't)
· avoided capital costs for air conditioning equipment, ranging from about $130 for a new building to about
$40 for a routine cooling-system renovation likely to occur in the '90s
· halved uninterruptible-power-supply capacity, cutting its capital cost by about $200 where it's used
· typically about one-fifth smaller plug-load wiring capacity, potentially saving another $200 or so (if the
electrical engineer pays attention to the reduced load!)
· possibly lower transformer costs because of reduced computer-power-supply harmonics
· much larger avoided costs (up to thousands of dollars per workstation in difficult cases) for upgrading old
offices' wiring and cooling capacity to accommodate inefficient office equipment and its harmonic
generation
TTFN
The most recent work that I have a copy of is seven years old at this point, and doesn't address LCD monitors at all. I don't know if they have been continuing.
A late-model HP laptop DV9843 uses a 90W AC adaptor, which is >20W more than what older laptops use.
An HP Pavilion Elite m92002 desktop uses a 350W power supply, older PCs used 150W or 250W power supplies.
An HP Pavilion w1707 LCD display is spec'd at 37W, while the two crts in my office are both tagged at up to 250 W.
So, while displays might have gone down, somewhat, in power, larger and brighter displays will burn a sizeable amount of power. The desktops have not gotten lower in power, but more, as indicated by the power supply requirements.
TTFN
Multiple CD/DVD drives, possibly in burn mode, 15 USB devices, Wi-Fi, BlueTooth, two or more monitors, all while running at 100% processor capacity.
Most typical users will never approach the need for the power supply's full output, and even those that do won't do so for extended periods of time.
They list the average power consumption of an EnergyStar LCD monitor at 28W and the average consumption of an EnergyStar computer at 104W.
A conservative number would be to assume 150W of heat gain from a single computer at 'peak conditions'.
Moreover, almost all the EEs amd MEs are running PCs with souped up graphics and central processors for CAD, so they're nowhere near the low side of power consumption.
While EnergyStar is certainly a datapoint, it's only marginally relevant to a generalized heat load design, since even if the initial agreement is to only use EnergyStar equipment, there's no guarantee that future occupants will be held to the same constraints.
TTFN
The major difference in EnergyStar (as far as I can tell) is that they come with an automatic shutdown, or hibernation mode, to reduce usage to 2-5W during periods of non-use.
The second spreadsheet shows numbers from monitors.
