Pump power calculation
I have the following situation:
3 coolingwaterpumps, 3 different coolingwater users with gascoolers, coolingwaterpressure reading, coolingwaterflowreading.
Can I use the formula as mentioned below for calculation of the pump power?
We don't have an accurate powerreading on the pumpmotors, but we want to have an idea of the pumppower when changing the flow, pressure and when we do other adjustments in the coolingwater system.
This is the formula:
Ph =(q*rho*g*h)/3.6*10^6
Pshaft = Ph/motorefficiency
unit's are in SI
Thank you in advance,
Cryotechnic
unit's are in SI
Cryotechnic
"Math is the ruler of your potential succes...."
RE: Pump power calculation
(read pump's efficiency at its flowrate off the pump curve)
Power Input to Motor = Brake Power/Motor Efficiency
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
l/sec x h(m)x S.G. / 102 x pump% = Kw (pump shaft)
(L/s)(m)(kg/L)(m/s2) = kg.m2/s3 = W
Q → L/s
H → m
ρ → kg/L
g → 9.8 m/s2
If you divide by 1000 and by the system's efficiency as a decimal, you get the equation given by Artisi (expressed in kW)
in my formula
q = m3/h
rho = kg/m3
g = 9,81
h = m
The formula for liquid horsepower (Ph) expressed in kW, is OK.
Pshaft (aka brake horsepower) is wrong. The efficiency should be pump's effy. not motor's.
