Joint Efficiency
3
Joint Efficiency
Joint Efficiency
I'm designing an aluminum pressure vessel. Shell and
head material is SB209-5083-O. Shell weld is Type 1
and torispherical head is seamless. There are no radiogragraphy for this vessel. What efficiency will
I use for the required minimum thickness calculation
for the head?
I'm using a 0.70 efficiency for the shell thickness
calculation.
Appreciate any help on this matter.
RE: Joint Efficiency
Hi Estssoc,
The Table UW-12 specifies E=0.7, as you mentioned, for no radiography design of the shell. Since the head is seamless, use E=1 for the dished end calculation.
cheers,
gr2vessels
Thanks guys. Appreciate the help.
I'll use 0.85 efficiency per UW-12(d).
