Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...thank you for the wonderful resource that you have enabled here. It is clear, concise, well maintained and most importantly, helpful..."
Geography
HighPanda (Civil/Environmental)
20 May 08 13:56
A want to do some VBA codes on a spreadsheet and the codes can run automatically.
For instance, if I input assign 1 to A1 and 3 to B1, I want to write a set of codes behind a cell, say, C1 to work out sum of A1 and B1 and display the result in that cell.
I remember there is a command(s)/statement(s) which will trigger Excel to run the program as long as the content in either cell A1 or cell B1 is changed, but I can't remember now.....
Can anybody help me?
HP
Denial (Structural)
20 May 08 18:18
I think you want the Worksheet Change event handler.  Here is a skeleton bit of code for it.
CODE
Private Sub Worksheet_Change(ByVal Target As Range)
'  Do the necessary things when the worksheet changes.
'  The EnableEvents=False serves to prevent recursive behaviour,
'  where the event-handler makes a change to the spreadsheet that in
'  turn re-triggers the event-handler, and so on, ad infinitum.
'  When you disable EnableEvents, you must make sure it is re-enabled
'  later.
Application.EnableEvents = False
'  Code placed here will be run if a change is made to ANY cell in
'  the worksheet.
If Not Intersect(Target, Range("YourNamedRangeOnSheet")) Is Nothing  Then
    '  Code placed here will run only if the spreadsheet cell that is
    '  changed is inside "YourNamedRangeOnSheet".
End If
'  Now all required work has been done, turn EnableEvents back on.
Application.EnableEvents = True
End Sub
This code lies behind the appropriate sheet object, not in a general module.
Hope this helps.
cummings54 (Chemical)
21 May 08 15:25
You can use the intersect method to tell if a changing cell in one of interest.  For example,
CODE
If Intersect(Target, Range("A1,B1")) Is Nothing Then Exit Sub
Range("C1").Value = Range("A1").Value + Range("B1").Value
End Sub
21 May 08 15:50
Thanks!!!!
Close Box
Join Eng-Tips® Today!
Join Us             Close
