Flatness/Parallelism Question
Hi All-
I have what might be a simple question that I can't wrap my head around. I'm working to Y14.5-1994.
If I have a square block of metal, and I state that I want one surface to be datum A and be flat within, say, .005". The I have the opposite surface that I want to put a parallel callout on. Can the parallelism be tighter than the flatness?
My immediate inclination is to say no, but I'm not positive. Please let me know what is correct, and the reasoning behind it.
Thanks for the help.
V
RE: Flatness/Parallelism Question
ht
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
V
The web site you suggest just doesn't seem right. It states that flatness is created from a 3 point set up (yes I agree) but then it states that this is the mid plane which is not correct. It goes on to state that a 0.25 flatness is 0.125 on either side of the 3 point set up which is not correct.
Flatness is a unilateral tolerance in which the surface must not exceed using a 3 point set up to create a plane. It can also be performed on a CMM with a scan mode using a best fit condition.
vc66
I cannot find anything in the standard that states that the flatness tolerance must be less than the parallelism but it does make sense.
Once we have a flatness requirement that is met, we then have a datum that is assumed perfect. From a 3 point set up on the datum surface we can check the opposite side for parallelism.
Theoretically, we should be able to place the datum surface on a flat plane simulating assembly to check the parallelism but if the surface was convex at all, we could not check the parallelism. The part would rock.
Dave D.
www.qmsi.ca
If I recall in the previous question the datum A surface didn't even have a flatness call out. The other side had a parallellism to datum A. Looking at 14.5 6.6.3 7 figure 6-30 this was a perfectly legit callout.
Plane A is derived from the corresponding surface but is not the same as it. The parrallellism is: "a tolerance zone defined by two parallel planes parallel to a datum plane or axis, within which the surface or center plane of the considered feature must lie".
So I would say that yes the parallelism to datum A can be tighter than the flatness of datum A. If this in practice achieves what you are trying to get is another matter.
KENAT, probably the least qualified checker you'll ever meet...
The danger is that increased flatness error on the datum feature leads to increased potential for convex shape and rocking. If the simulator (surface plate) rocks relative to the convex datum feature, the parallelism tolerance zone rocks right along with it.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
Thanks for all the replies.
V
