Return air VFD fan control with return air static pressure
Have a question on how to apply this correctly.
The return fan speed with be controlled with a static pressure transducer in the return duct.
my question is where to put the pressure xducer and is it suction that i need to measure.
This is what I'm using for supply duct pressure after the supply fan
http://www.mamacsys.com/PR-276features.htm
Not sure if this will work for return.
RE: Return air VFD fan control with return air static pressure
What is the goal?
ok nevermind. I read the control sequence wrong.
not sure what its goal is.
The goal is typically a high limit on suction side (say above 2") to disable the fans before you get a sucked in duct.
