Delta Wing leading edge vorticies
i have some simple questions for you. At the moment i do some research in the field of flapping flight. To understand the vorticies of this flight i need some informations about leading edge vorticies.
For delta wings: At which angle of attack appear vorticies seperation from the airfoil?
how is the geometry (AR, sweep) ?
Thanks for your help.
RE: Delta Wing leading edge vorticies
for starters, then see the references at the end.
google "aerodynamics", "delta wing"; maybe go to the NACA site "http://ntrs.nasa.gov/search.jsp" ... it is truly amazing what is out there. then maybe come back with a concise question.
