(4 +ö series 8 bolt) need requird information
(4 ¾" series 8 bolt) need requird information
4 ¾" series 8 bolt
Nominal Size = 4.75
Bolt root Area =
Minimum Bolt Spacing =
Radial Dstance h =
Radial Dstance r =
Edge Dstance =
Nut Dimension Across flats =
4 ¾" series 8 bolt
Nominal Size = 4.75
Bolt root Area =
Radial Dstance h =
Radial Dstance r =
Edge Dstance =
L S THILL
RE: (4 +ö series 8 bolt) need requird information
Check out this web site, it looks like they might have bolts in the size range you are talking about.
http://www.vfbolts.com/capabilites.htm
Good Luck
This size is only available in US standard with 2.625 threads per inch.
Bolt root area = 14.215 in2
Accross Flats = 7.25"
Nut height = 4.75"
The rest I suggest to extrapolate Table D-5 in TEMA to the bolt size (4.75")
My two cents..
gr2vessels
From http://
Bolt root area = 16.5 in2
Looks like you are adding a user defined bolt in Compress. Follow some of the recommendations in the manual... ht
What are the bolts for?
