convert TEKLA model to other formats
Hi there,
BASIC IDEA:
I want to export a TEKLA model (small steel structure with connections etc...) and import it to a FEA program such as ALGOR. I can easily design complex steel structures and connections with TEKLA, so the basic idea is to export the geometry from TEKLA and import it to a FEA program.
I want to export the Tekla model to a format that will be imported from ALGOR (for example .sat , .STEP etc).
I tried to export the TEKLA model to a 3D dwg model but the 3D model is not quite solid, it is structured from closed lines and polylines but this thing is not quite a solid so I can import it to ALGOR.
I tried several programs for this transformation such as TransMagic R7, Cadfix 7.1 without any result.
Any ideas to make this transformation work?
Thanks in advance.
RE: convert TEKLA model to other formats
I don't know of anyone who uses DWG for 3D solids , have you tried IGES ?  Are you allowed to post the file ?
IGES should work so long as it is trimmed surface (144 entities?).  I have also successfully imported .sat and .step files.
It depends a great deal on how TEKLA (not familiar with that software) writes the export geometry no matter which FEA package you are reading in to.  Complex surfaces are not generally well-described.  I recommend you build a very simple model in TEKLA and once you find an export format that works, slowly make the model more complicated.
