covert TEKLA model to other formats
Hi there,
BASIC IDEA:
I want to export a TEKLA model (small steel structure with connections etc...) and import it to a FEA program such as ANSYS. I can easily design complex steel structures and connections with TEKLA, so the basic idea is to export the geometry from TEKLA and import it to a FEA program.
I want to export the Tekla model to a format that will be imported from ANSYS (for example .sat , .STEP etc).
I tried to export the TEKLA model to a 3D dwg model but the 3D model is not quite solid, it is structured from closed lines and polylines but this thing is not quite a solid so I can import it to ANSYS.
I tried several programs for this transformation such as TransMagic R7, Cadfix 7.1 without any result.
Any ideas to make this transformation work?
Thanks in advance.
BASIC IDEA:
Thanks in advance.
