Nodelock license not available in Catia
I have Nodelock license which I successfully Imported with Nodelock Key Management tool. But in Catia this license is not available in Licensing tab at Options (it is grayed out).
A Product that this license is for is installed in Catia correctly.
RE: Nodelock license not available in Catia
Can you post an image of your license from the nodelock manager (using the read function)
If all else fails go to C:\Documents and Settings\YOUR USER NAME\Application Data\DassaultSystemes\CATSettings
Look for the Licensing.Catsetting file and delete it. Close Catia and start it again and it will ask you to choose a license.
Hope this helps.
My license is now working. For some reason I got first incorrect nodelock .lic file.
