University Research project - Radial Spark discharge
Hey,
I am currently designing a radial arc discharge ignition system for a Pulse Detonation Engine; I have a few questions that maybe you can help me with.
1. Can anyone recommend a paper that has investigated the Lorentz force acting on a spark, in particular the spark velocity to magnetic field strength relationship?
2. Can anyone suggest a supplier for Neo radial magnetized rings that will do evaluation quantities?
Cheers
Andrew
Cheers
Andrew
RE: University Research project - Radial Spark discharge
I wish I could be of assistance, but I can't.
However, that's an interesting project you're on. I was just reading a bit on it yesterday. I was curious to see the difference between the PDE and the old pulse-jet technology.
Good luck!
old field guy
I'm not aware of anyone supplying evaluation quantities of fully sintered radially oriented Neo rings. They are generally very expensive to tool up.
What magnetic field strength do you need? Can you work with compression bonded Neo? That type of Neo is isotropic and can be magnetized radially. They are not as strong as fully sintered, but much more available.
There are other methods that might work, but it would help to know your magnetic field requirements (hopefully not "as strong as possible").
Also, I'm not aware of paper dealing with spark behavior and magnetic fields
Mike
Mike
oldfieldguy: The difference between PDE and regular pulse jet is that the pulse jet burns fuel where as the PDE detonates the fuel as in an explosion more bang for your buck so to speak.
MagMike: The thing is that the stronger the magnet the higher the spark velocity I can achieve this will give the cleanest focal point of the flame front, but from my calculations looking for about 1 T. Compression bonded would be fine I guess.
MJR2: Demagnetizing though heat isnt a big worry beacuse the total test time is about 2 seconds and I was thinking of insulating the magnet in a resin too.
thank you for the help
Your best bet may be to use two axially oriented NdFeB rings with a steel ring in between. The NdFeB rings would have their North poles in contact with the steel, driving flux through the steel in a radial direction. You'll need a strong adhesive to keep the magnets bonded to the steel.
The next question would be: What diameter rings are you looking for?
Andrew
http:
