Timed pneumatic valves?
Does anyone know of pneumatic valves that can be set to actuate air on for a specified period time after a specified period of time has elapsed?
I have never worked with something like this and am just looking for a name if it exists.
windo4life
windo4life
RE: Timed pneumatic valves?
Depending on the flow rate you need you may be able to use a pneumatic timer directly, or need to use one to pilot a larger valve.
Doubtful that they are cheaper or easier to install.
Pneumatic logic is really neat stuff, but there aren't too many folks around anymore that really understand it.
Anyway, a Google search for "pneumatic logic" will get you on the right track.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
I found Kuhnke quickly with your suggested search term, http://www.kuhnkeusa.com/timersandcounters.php
ISZ
I have become interested in it though, very neat technology. I've performed a few web searches but haven't found many resources. Please post if you know of any.
windo4life
http://www.rosscontrols.com/
Look at the Series 27 valves and possibly others..
You might check Numatics and others also.
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING
One example here:
http://ww
Their prices haven't gone up much in the intervening decades.
They are, or at least were, reliable and durable.
They used to stock nice plastic manifolds to implement common functions.
Mike Halloran
Pembroke Pines, FL, USA
