Swept Feature
Swept Feature
I've created a wavy path made from half circles tangent to each and where all the circles follow a circular pattern. I've created a half circle as the pattern and pierced it to the path. I'm trying to create a sweep (like a wavy bead that runs around a part in a circular fashion), but the feature will only sweep the first single half circle it is pierced to, and not the entire path of tangent half circles. Is there something I need to do to "tie together" the series of half circles that make the path?
RE: Swept Feature
If all of the lines are in the same sketch, then select them all, right-click and choose "Make Path".
That should get you where you need to go. Also, you don't need the pierce constraint for sweeps.
Dan
www.eltronresearch.com
RE: Swept Feature
RE: Swept Feature
RE: Swept Feature
Jeff Mowry
www.industrialdesignhaus.com
What did you dream? It's all right--we told you what to dream.
--Pink Floyd, Welcome to the Machine
RE: Swept Feature
John
