Cooling Coils
Cooling Coils
2 Questions:
1. How do cooling coils collect condensate when they are mounted in a horizontal position? In vertical position it drips off the face and into a pan is easily understood, but wouldn't some kind of horizontal coil pan collector disturb air flow? Anyone have any pics?
2. In terms of VRF (variable refrig flow), does each fan coil have its own TXV? Does the refrig self flash as it gains heat from the air? Wouldn't the refrig return in different states & temps on the suction side?
RE: Cooling Coils
For a view of the "H" coil go here: http://w
