My Macros stopped working with upgrade
We updated to SW 2007 sp5 over the weekend and none of our macros are working any more. When I go to debug, it yellows out the Sub main () in the first code line. Does anyone have any ideas of what would be causing this or how I could fix it?
Here's the one I tried to run this morning.
Option Explicit
    Dim e As Long
    Dim w As Long
    Dim dxfver                  As String
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim sPathName               As String
    Dim s12DXFPathName               As String
    Dim s14DXFPathName               As String
    Dim sPDFPathName               As String
    Dim sCNCPathName            As String
    Dim swDraw              As SldWorks.DrawingDoc
    Dim nErrors                 As Long
    Dim nWarnings               As Long
    Dim nRetval                 As Long
    Dim bRet                    As Boolean
    Dim bRet2                    As Boolean
    Dim bRet3                   As Boolean
    Dim Part                    As Object
    Dim SelMgr              As Object
    Dim boolstatus              As Boolean
    Dim longstatus          As Long, longwarnings As Long
    Dim Feature             As Object
____________________________________________________________
Sub main()
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swDraw = swApp.ActiveDoc
    Set SelMgr = swModel.SelectionManager
   ' swModel.PrintDirect
     ' Strip off SolidWorks drawing file extension (.slddrw)
    ' and add DXF file extension (.dxf)
    sPathName = swModel.GetPathName
    sPathName = Left(sPathName, Len(sPathName) - 7)
    s12DXFPathName = sPathName + ".dxf"
    's14DXFPathName = sPathName + "_R14.dxf"
    sPDFPathName = sPathName + ".pdf"
    'sCNCPathName = sPathName + "_CNC.dxf"
    dxfver = swApp.GetUserPreferenceIntegerValue(swDxfVersion)
    swApp.SetUserPreferenceIntegerValue swDxfVersion, swDxfFormat_R12
    swApp.SetUserPreferenceIntegerValue swDxfOutputNoScale, 1
    bRet = swModel.SaveAs4(s12DXFPathName, _
         swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, _
            nWarnings)
    If bRet = False Then
        nRetval = swApp.SendMsgToUser2("Problems saving DXF file.", swMbWarning, swMbOk)
    End If
    bRet2 = swModel.SaveAs4(sPDFPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, _
            nWarnings)
    If bRet2 = False Then
        nRetval = swApp.SendMsgToUser2("Problems saving PDF file.", swMbWarning, swMbOk)
    End If
    'swApp.SetUserPreferenceIntegerValue swDxfVersion, swDxfFormat_R14
      'bRet3 = swModel.SaveAs4(s14DXFPathName, _
         'swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, _
            'nWarnings)
    'If bRet3 = False Then
        'nRetval = swApp.SendMsgToUser2("Problems saving DXF file.", swMbWarning, swMbOk)
    'End If
   'swDraw.ActivateSheet ("program")
    'bRet3 = swModel.SaveAs4(sCNCPathName, _
            nWarnings)
       ' nRetval = swApp.SendMsgToUser2("Problems saving DXF file for programming.", swMbWarning, swMbOk)
    'End If
    ' Restore old setting
  swApp.SetUserPreferenceIntegerValue swDxfVersion, dxfver
    Set Part = swApp.ActiveDoc
    Set SelMgr = Part.SelectionManager
    Part.ViewZoomtofit2
    Part.Save2 False
    Set Part = Nothing
    swApp.CloseDoc (sPathName)
Boottmills
RE: My Macros stopped working with upgrade
What version did you upgrade from?
Try going to tools->References.  Check to see if any are missing, and re-order them a bit.  Sometimes you just have to force it to look for them again.
-handleman, CSWP (The new, easy test)
I upgraded from SP2 to SP5. I'm going to check the references and see what happens..I'll let y'all know!
Boottmills
YOU DA (HANDLE)MAN!
It did the trick! Thanks!
Boottmills
