Particular Material Appraisals filled form
Can some one help me with a filled PMA form for A106 Gr B and A333 Gr6 material.
RE: Particular Material Appraisals filled form
Go here and review this document, it looks like it should answer your question;
[PDF] Guiding Principles for the contents of Particular Materials ...File Format: PDF/Adobe Acrobat - View as HTML
A Particular Material Appraisal (PMA) is the process by which the pressure ... Guideline 7/12), however, it may be appropriate to utilise this form of ...
ec.europa.eu/.../ped/materials/PE%2003-28%20Guiding%20principles%20for%20the%20content%20of%20PMA.pdf
Thanks for the reply. I do have the PDF document. What I am looking for is a filled in document. The pDF doc is a bit confusing.
MenonMott,
          I can psooibly send you a typical one for A106 GrB if you advise E-mail Address but bear in mind that for piping you also need PMA's for the fittings/flanges etc.
DSB123,
Thanks for your reply.Please send it to my id crmenon64@yahoo.com.
