Signal wires for ac drive.
I'm installing a small frequency drive to run a grinding aid pump for a large ball mill. I need a 4-20 mA signal to the drive to control the speed, and another 4-20mA signal back to a plc for current feedback. I have a shielded cable that's already in place that contains two twisted pairs. I'm wondering if this cable is adequate or do i need two pull another one where each pair is individually shielded. Wire pulls in the mill building can be pretty ruff with all the dust and transitions from cable to tray.
This is my first post, I'm an Electrician and Instrumentation tech at a cement plant. I'm looking forward to being a part of this forum.
RE: Signal wires for ac drive.
Welcome to the forum BTW.
I would agree with Scotty. Keep your cables away from the motor cables where possible, but if you have to cross then cross at 90deg.
