Safety factor changes in ASME VIII Div 2?
Since 1965, have there every been changes to the allowable stress safety factors in ASME VIII Div 2?  The reason why I ask is that I am trying to apply API 579 Section 3 to develop a Temperature/Pressure envelope for start-up/shutdown of a reactor.  According to API 579, if my vessel was made to Div 2, Temperature restrictions must be observed when I surpass the 30% MAWP value (8 ksi level).  However, old (pre API 579) original documentation stated that the limit was closer to 25% MAWP but did not explain why.
RE: Safety factor changes in ASME VIII Div 2?
Yes, there have been changes in allowable stress values in ASME B&PV Code Section II as more test data is obtained and more operating expierence with boiler and pressure vessel materials. Are you aware that Section VIII, Division II was completely re-written for the 2007 Edition of the ASME B&PV Code?
Were the safety factors any lower than 30% in 1965?
For many materials the factors went from 1:4 to 1:3.5.  That is only 12.5%.
Plymouth Tube
Sorry, what I meant to say was, was the 8ksi level lower than 30% MAWP before 1965?  The material in question is ASTM A387 Gr. D.  Sorry I don't have a copy of that code, otherwise, I'd look it up.
