Current versus load for split phase motor
I want to adjust the load (a fan) on a new split phase motor (3/4 hp, 120 v, 60 hz) so as to absorb rated power. I planned to adjust pully ratio until I achieved the rated FLA of 11.1 amps. Imagine my surprise to find the no-load current was about 12 amps and the current did not change appreciably when a moderate load was applied. What's going on? How do I decide how much load to apply? Is something wrong with this motor? (It starts and runs OK and sounds normal.)
Thanks for any advice.
Jerry Jackson
San Antonio
Jerry Jackson
San Antonio
RE: Current versus load for split phase motor
Keith Cress
This means you have a a relatively high reactive load and resistive loss load even at no-load. The increase in resistive component due to mechanical loading can be relatively small compared to the no-load components.
