Flow rate calculation?
If I have my static and residual flow pressures and I know my pipe sizes and equvelant pipe lengths for fittings, how do I solve for gpm? For example a 2" main drain test with 75 psi static and 65 psi residual; with 10' of sch 40 steel c factor 120, (2) 90s and (1) angle valve. Can I use a variation of the Hazen Williams formula to do this? I have it attached wher I solve for pressure loss. Can I change this around and if so how?
RE: Flow rate calculation?
Fire Sprinklers Save Firefighters' Lives Too!
Good luck!
Travis Mack
MFP Design, LLC
Draining down the system could more than double the amount of time required to test the DCVA, hence my interest in a mathematical solution. I would simply pitot the main drain (for light, OH1 and OH2) but 99% of the time (my guestimate) one would not have a piping arrangement that will give a good laminar flow.
Thanks LCREP
I had thought of this and wondered how accurate they were. Pretty expensive, but it would pay for itself eventually. Would you have a little more information on the make and model you used, if you recall, and your experiences with it?
Regards all
It was 5-7 years ago and do recall all the details, just the flows. I know we have still have the meter in the Training Center, next time I am at the center, I will get the name of the unit.
Tom
not an engineer that drives a train is there some reason that table 5-2A out of the fire protection handbook 7th edition cannot be used????
I have been trying to get a company to give me the hydraulic clacs to prove one system they are installing, to see if they can use the two inch drain.
I have to admit that your reference to train engineers slips by me... sprinkler engineers are like train engineers: not much going on? (don't want to start a war here though! :) )
Thanks for your replies cdafd.
