mixing water with compressed to make spray
Can I mix water with compressed air (both at the same pressure) together in 1 pipe by a normal T to make a spray flow ?
as follows :
water -------------------
-------------spray----------------------- to Nozzle
Comp. air ---------------
Can I do that ? If yes how can I size the spray pipe ?
as follows :
RE: mixing water with compressed to make spray
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING
There is a nozzle installed in a vessel.
We need to feed "spray" to this nozzle .
Spray : compressed air + water (I don't have the mixing ratio now).
But I like to know is it right to mix water & air by this way or there are other methods for this type of mixing?
Or: http:
Or:
http://www.spray.com/products/air_atomizing.asp
Ted
