PED Welding requirments
We have an ISO compliant welding qual. process using the ASME Boiler & Pressure Vessel Code, section IX as a guide. We are also trying to sort through EN 287-1 & EN 15614-1 to comply with TUV directions for PED requirements. I was wondering if anyone has experience trying to implement the TUV welding requirments to these EN standards and the challenges you faced.
RE: PED Welding requirments
Every time I hear their name I wonder what interpretation they are going to come up with next.
If you design and manufacture to ASME VIII then weld to ASME IX.
Check out the essential safety requirements of the PED, here is the details from 3.1.2 Permanent Joining
There are a number of details in this that tell you that ASME IX procedures are acceptable.
'...suitable operating procedures...'
is the most obvious one.
'...or equivalent examinations...'
is another.
Simply get your notified body to approve your ASME weld procedures or, if you have weld procedures approved by a third party organization recognized by a Member State, get TUV to accept them.
Now, be careful with this last bit, with materials TUV were telling everyone they had to get material suppliers approved by a notified body, section 4.3 of the essential safety requirements was worded in a similar manner.
The third party has to be recognized for approving weld procedures by a Member State (a nation that is a member of the European Union), that is all. This is to ensure that there is somebody resident in a Member State who could be held accountable for their work.
I hope this helps.
Previous German national ntandards (DIN) on welder qualification included a written job knowledge test. That is why Annex C is included in EN287, but note its not mandatory. However TUV tried to push it through for all work where Germany was the end destination of the welded product. When I worked for a filtration/PV manufacturer in the UK, the welders had to undergo a job knowledge test. Keep it simple though and dont scare away your welders!!!
Nigel Armstrong
Karachaganak Petroleum
Kazakhstan
Personally, if you don't already do it and you have approved welding procedures I wouldn't do the written test.
If TUV insist, get another notified body.
Hartford Steam Boiler and their Notified Body, HSB International, allow the ASME Section IX to be used to qualify PED WPS and WPQ. You do have to perform additonal tests on the PQR coupon, but all ranges, positions, etc. are per Section IX. Much nicer if you are using Section IX ASME already. You don't buy (or look at) any EN standards at all.
Full Disclosure: I work for HSB. They have problems with the PED implementation in the US like all notified bodies, but their welding method is the best by far for existing ASME Certificate holders with Section IX knowledge, in my opinion.
A list for all Notified Bodys to PED, are listed here
ht
