Beginner Python Script Problem
I am just learning Abaqus (both main program and scripting) so I will apologize ahead of time if this is a dumb question.
I have written the script below to create an axisymmetric part that I will then use Abaqus to analyze. But when it gets to the last line of the code I get the error "Shell extrude feature failed". My first guess was that the endpoints of the first and last line are not connected to the endpoints of the spline. But after manually drawing it and looking at the .rec file I don't see anything in that code specifying this connection either.
I need to use a spline because eventually the sketch will not be a simple circular arc.
Does anyone have any suggestions?
Any help is appreciated.
Dan
<CODE>
import math
from part import *
from sketch import *
model=mdb.models['Model-1']
# Basic lens data
lensS1SemiDiameter=15.0
lensS2SemiDiameter=15.0
s1Radius=20.0
s2Radius=100.0
centerThickness=8.0
# Number of increments to split the semiDiameter into
numOfIncrements=15
s1SemiDiameterIncremement=lensS1SemiDiameter/numOfIncrements
s2SemiDiameterIncremement=lensS2SemiDiameter/numOfIncrements
surfValues=[]
curY=0
curNum=0
while curY<=lensS1SemiDiameter:
curSagValue=s1Radius-math.sqrt(s1Radius**2-curY**2)
surfValues=surfValues+[(curY,curSagValue)]
#print "surfValues=",surfValues[curNum]
curNum=curNum+1
curY=curY+s1SemiDiameterIncremement
# Create the sketch
sketchName='test'
model.ConstrainedSketch(name=sketchName,sheetSize=200.0)
theSketch=model.sketches[sketchName]
# Pass the array all at once to the spline command
theSketch.Spline(points=(surfValues))
# Conncect the spline end points with lines
theSketch.Line(point1=(surfValues[0][0],0.0),point2=(0.0,-10.0))
theSketch.Line(point1=(0.0,-10.0),point2=(15.0,-10.0))
theSketch.Line(point1=(15.0,-10.0),point2=(15.0,surfValues[15][1]))
# Create the part, name it, and set the sketch to it
partName='tmpLens'
model.Part(dimensionality=AXISYMMETRIC, name=partName, type=DEFORMABLE_BODY)
model.parts[partName].BaseShell(sketch=theSketch)
Dan
<CODE>
import math
from part import *
# Basic lens data
s1Radius=20.0
s2Radius=100.0
centerThickness=8.0
numOfIncrements=15
surfValues=[]
curY=0
curNum=0
curNum=curNum+1
# Create the sketch
sketchName='test'
partName='tmpLens'
RE: Beginner Python Script Problem
Thanks xerf. That did the trick.
