Dimensioning problems
I know this has probably been covered before but I really need some help with this.
I have given a drawing a dimension of lets say 14.5
It is showing 14.998 I have tried to change the precision it seems to cover the problem but doesnt fix it. Also I have been looking for a "exact" dimension setting in the standards with no luck. I am not sure how to fix this.
Any Ideas?
RE: Dimensioning problems
Don't fix the drafting, fix the model!
Ben Loosli
What release?   There was a problem at one of the R17 releases that caused this in 3-D.
In the Drafting world, look to the orientation of the view - if the view is a little skewed it can cause this, as the geometry may be foreshortened.
does this happen on all your drawings?
does this happen with all dimensions on all views?
a screen shot would help!
I have found that setting the decimal precision to a minimum of 5 places helps eliminate this kind of problem.  It may not be the answer to your problem, but FWIW...
Catia Design|Catia Design News|Catia V5 blog
