Table J2.4
Table J2.4
I want to ask about the change in the minimum size of a fillet weld in 13th AISC. I dont have the AWS code, and was wondering about using a 1/4 plate to a much thicker plate. My minimum weld can be 1/8", but what is the preheat requirements now to weld that to say a 2" plate? If I use the 12th AISC, I would just spec a 5/16" weld, and be covered for preheat requirements correct?
RE: Table J2.4
RE: Table J2.4
RE: Table J2.4
It has something to do with the fact the any larger weld ruins the edge of the thinner plate and then you don't know what you have.
RE: Table J2.4
