type of gasket
type of gasket
type of gasket
what type of a gasket to use for flange 12" ANSI B16.5 CLASS 300 R.F. (16 HOLES)
RE: type of gasket
What fluid are you trying to contain, at what temperature and what pressure?
Details, please!
RE: type of gasket
in the low pressure oil system, just paper (garlock)
in the low press steam system, flexitalic with stop ring
RE: type of gasket
its Gas,at 600-700degrees.
RE: type of gasket
Gas at 600 - 700 degrees - are you sure?
RE: type of gasket
yes,the (300 diam)duct will operate at that temperature which is why its hot insulated.
RE: type of gasket
What unit of measurement> Celsius or Fahrenheit?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
