Layers
Layers
So I'm in my sketch (part) and I have many sketches laid over each other to distinguish geometry because many drawings share the same geometry.  When I take it to a drawing to transfer to mastercam X2 using mastercam direct I want to make layers of each sketch that I can switch on and off when I code the geometry in MCX.  I know how to open the toolbar for the layers, but I can't figure out how to make individual layers for each sketch.  What am I doing wrong!  I know you can od it in AutoCAD. I know how to make the layers in Mastercam, but not solidworks.  Help!
RE: Layers
Are you modeling parts, or creating a bunch of sketches in a drawing?
SolidWorks is not the same as AutoCad.
-Dustin
Professional Engineer
Certified SolidWorks Professional
RE: Layers
I agree with Dustin.
If you are not creating models and only sketches in drawings, I suggest using only AutoCAD.
In SolidWorks "Help", search for 'layers'.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
RE: Layers
Ok I figured it out.  Hmmmm I guess Solidworks really isn't like AutoCAD after all!?!?! What?  Weird?
RE: Layers
Weird?
It's not supposed to be like AutoCAD.
Black and white.
Chris
AutoCAD 06/08
