Drawing .PDF question
When I print a .PDF of my drawing with the models in the "shaded with edges" view the border of my .PDF turns very light, nearly gone. When I print the same drawing with the models in the "hidden lines removed" view the border is correct (dark). Anyone else have this happen? Did you find a fix?
BB
BB
RE: Drawing .PDF question
BB
More info:
http://
I will try options tomorrow.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
-Dustin
Professional Engineer
Certified SolidWorks Professional
Flores
TheTick - I am on 2007 sp 5.0.
ShaggyPE - Your suggestion does the trick, thank you very much.
Thanks to everyone for their suggestions but ShaggyPE's suggestion was right on the money. If I do a "Save As .PDF" then go back and print it, it looks perfect.
BB
