Pipe Insulation
Pipe Insulation
When people specify aluminum jacketing and insulation for outside refrig or chilled water piping, what is the insulation underneath. Is it better to use like a foamed plastic Rubatex or urethane Armacell? They are not just stuffing fiberglass wrap and then putting aluminum around it are they? What is the best insulation for piping outdoors?
RE: Pipe Insulation
The aluminum jacket will keep it from UV damage, make it last even longer.
My experience and opinion only -- let's see what the others have to say.
Goober Dave
RE: Pipe Insulation
htt
There are also aluminum-jacketed fiberglass systems.
RE: Pipe Insulation
RE: Pipe Insulation
DX can use a armaflex design with latex paint or jacket to minimize UV degradation.
RE: Pipe Insulation
Of course, PVC, Aluminum or even stainless steel jackets as indicated above are the norm.
