180 Degree Dimension
Dumb question of the day... How do you get a 180 degree dimension to show up?
RE: 180 Degree Dimension
Draw it at some other degree, dimension it, and then edit the dimension to 180.
Otherwise, set your relations to collinear or coincident.
Jeff Mowry
www.industrialdesignhaus.com
What did you dream?  It's all right--we told you what to dream.
    --Pink Floyd, Welcome to the Machine
SW doesn't handle 180deg dims very well, especially in mating.  If you really need to have an entity separated by 180deg from something, I would create an intermediate line/plane halfway there.  That way you have two 90deg dims.
