multiple users, best practice
All
I have been the sole user of SW in my company for many years now, this now is not the case as due to work load etc.. I have hired more staff to meet the demand. Basically when the first new guy came along with SW exp all was well as he worked on a separate project, now however I need the third guy to work on the same project. How is best to do this as the issue I have is two people need to be able to work on parts of the same assembly.
IF anyone has any tips it would be great!
James
SW2008 sp3.1
James
SW2008 sp3.1
RE: multiple users, best practice
Some members here use this in an of office of at least a dozen users. Others will tell you that PDM is a must. Both methods have their problems.
I would suggest trying the "multi-user" option first, because it is the simplest to implement and use.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo, 4GB RAM, Nvidia 3500M
With references opened as read-only, write-access is not tied up simply because a component file is open by another user who does not need write access. One gains write access to a component by either opening the file singly or by reloading.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
Works best. If you guys don't have it, ask your management to upgrade to Professional. It comes with it.
Arun
Mechanical Engineer.
Solidworks 2008,Inventor-2009,
Cosmosworks,CosmosMotion,CosmosFloworks.
