Ansys Workbench Question
Hi All i have been using Ansys Designspace for a number of
years, currently on version 11.
I believe that ansys designspace is good untill the yield of the material is exceeded then it becomes non linear and full ansys is required.
i Have accuired an evaluation dvd of all the ansys products
and have been having a play on my laptop at home, but no matter
what product i select ie Professional/LS Dyna etc
if i execute in ansys workbench i get only the same
functions as i get in designspace and results
Please Help
Stu
RE: Ansys Workbench Question
when opening Workbench, go to Options, License and check which license allocation sequence you have. In fact, if the "first choice" (default) is DesignSpace, you won't see the higher-level options even if as "second choice" (i.e. "first alternative") you have "Multiphysics".
Hi under the licence allocation i have all products.
if i use ansys product launcher i can selet all product
either under ansys or workbenchbut when i run these i only get same options as under deisgnspace no matter which product i select, see atatched
thanks
Hi, everybody:
I am a new user for ANSYS. How can I import Pro/E model into ANSYS workbench? I tried IGS file, but failed.
Jack
Hi Jack,
You should have ansys icon in the tool bar of your 3D modeler,you should be able to directly import your 3D model in to ansyswb by using the ansys icon in the tool bar.
