import a mesh from CFD to proE/Mechanica
Hi folks,
I have a problem to import thermal results from a CFDesign analysis to Mechanica. CFD generate a fnf file, I create an external temperature load in Mechanica using this file but during the calculation, it ends with this :
"Erreur fatale ; exécution terminée
Thu Apr 24, 2008 16:16:15
La maillage utilisé pour la définition du champ de température externe n'est pas cohérent."
What means that the mesh used for the external temperature field is not logical.
Does anyone use this type of import or have an idea on that point ?
Thanks a lot.
simon
Thanks a lot.
simon
