round expression value
(NX5)I'm using the expression for sheet metal thickness, in a text note on the drawing, but the expression comes out as 3.00 but i only want it to read 3  how can i round it down ?
RE: round expression value
Simple. By default the expression has two decimal places.
<X0.2@t> where t is the expression 3 is the value and 3.00 is how the note appears.
<X0.0@t> where t is the expression 3 is the value and 3 is how the note appears.
Because .2 was changed to .0 inside the note substitution text block. In that little coded statement the number after the decimal point dictates the number of decimal places used.
Best regards
Hudson
Thanks buddy
