multi-phase joules-thompson effect problem
Hi all,
I am currently using the NIST SUPERTRAPP database to determine the liquid/gas phase composition of a mixed fluid. The fluid is raw natural gas from a pipeline, and so contains c1, c2, etc plus some water.
Now, here is my problem. This fluid passes through a pressure regulator valve, where the pressure drops from 537psi to 200psi. I am trying to determine the final temperature of the mixture. When I use the NIST program, it gives me the option of doing a constant enthalpy expansion on the two phase mixture. However, I just noticed that the program is combining the enthalpies of both the liquid and gas phases to do this.
So, my question is this: to properly determine the amount of cooling due to the joules-thompson effect, do I need to do a constant enthalpy expansion keeping just the gas phase's enthalpy constant, or is it appropriate to do as the NIST program is doing and keep the total enthalpy for both gas and liquid constant?
At the moment, I am guessing that only the gas phase's enthalpy should be kept constant, as only the gas actually expands through the valve. But I am a mechanical engineer and so this is a bit outside my normal area...
Thanks everyone!
-ktgottfr
Thanks everyone!
-ktgottfr
RE: multi-phase joules-thompson effect problem
David
-ktgottfr
Keep in mind that the Joule Thomson effect concerns only gases and is an iso enthalpic process.
in addition having read that your stream contains water!! if it was a real stream you'll have a great Hydrate problem after passing the stream through a choke valve!! that's why in the gas treatment plant we process the gas stream through a dehydration column (to take rid of water!!)
Hoping it'll help!
