Analog water level sensor? anyone?
Hi, I'm actually an engineer in a COMPLETELY different sense. I'm an audio/computer engineer. but I want to measure fluid waves for a creative application.
I was hoping someone could point me to a relatively cheap method of sensing fluid levels in the analog domain. I need to sense either 0 to14 ft or 0 to5 ft. depending on the context (pool or ocean) I need very accurate resolution. I'll take anything but sub millimeter would be preferable. I have a sensor input box, which takes 0-5v and I've done some research and the closest thing I can find is a 1300 dollar capacitive sensor which digitizes all of it's information.
I guess I'm kind of looking for the capacitive part and not the digital part.
anyone ever heard of something like this?
RE: Analog water level sensor? anyone?
do you think I could accurately turn an ocean wave to sound (adjusting for speed of course) using this method?
Typically for water, it is common to simply use a pressure transmitter to measure the water pressure, e.g.:
htt
And if you spend a little time search Eng-Tips, you will find the longest thread in the history of instrumentation devoted to measuring down-hole level of a well or something (I'm trying to erase it from my memory).
Dan - Owner
http://www.Hi-TecDesigns.com
Milltronics (now owned by Siemens) makes the best IMHO. To be fair, I am a Siemens employee but that is an entirely separate division. I used Milltronics for years long before Siemens bought them. 2 versions worth considering:
https://pia.khe.siemens.com/index.aspx?Nr=11159
https://pia.khe.siemens.com/index.aspx?Nr=11157
yes
jraef ,
I called siemens this afternoon and they said that the sampling rate was to low which didn't make much sense to me, but I guess it's digital
Drop a weighted insulated wire into the wave (teflon insulated wire is the best Make sure you insulate the end well or double it back to the surface. Now you have a variable capacitor that is proportional to the immersion depth (one plate is the water, the other the wire.
Use the capacitor in an audio oscillator or some other circuit that will measure the value.
Now you have a capacitance level transmitter. It may not give you the accuracy you asked for but will have very fast response.
If you need more capacitance use more lengths of wire or a probe with large surface area.
Good Luck
Roy
Keith Cress
ht
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
As for virtualization, I think it might get low frequencies approximately right, but not the high ones. Also not directly come from nature, chaos, speed boats etc. artsy fartsy crap.
I'm hoping you can hear the tides if I speed it up enough.
Also The idea was dual purpose. Liquid obviously doesn't operate like the skin of a drum or a string. I thought it might be cool to get in an oddly shaped pool and do cannon ball Rhythm tracks!
They're putting some rather realistic physics modeling behind some OGL visual water surface simulations and getting very realistic results, if you're interested.
