Crane Resistance Coefficient (K factor) for Pipe Elbows
In Crane TP410, on page A-29, there is a table for K values of 90 degree pipe bends as a function of r/d. I deal with many r/d values in between the increments in the table. For the purposes of putting K in spreadsheet formulas, is there a generally accepted curve fit for K as a function of r/d?
I realize I could make a lookup table and interpolate, but this would make the spreadsheet much more complicated. I am also aware that there is considerable variation in the data as seen in the graph on Crane page 2-13.
Garrett
Garrett
RE: Crane Resistance Coefficient (K factor) for Pipe Elbows
http:
You could fit a curve to his data and convert from Le to K
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
Garrett
Since it's Crane's book, any "official" curve fit or underlying formula would come from them. They have a website (www.crane.com).
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Thank you
Leonard
Or perhaps you need a more accurate answer from your calcs than a conservative assumption would provide (?)
ValveEngineer
That is the type of function I was looking for. I wanted to avoid splitting the range in two, so I came up with:
K = a( atan(r/d) ) + b (r/d)-1 + c (r/d)0.5
where,
a = -19.1084132244392
b = 17.0419398956139
c = 17.487997553414
I did not find anything on the Crane web site http://www.cranevalve.com/.
The systems I am looking at have many bends, so I do not want to build in a conservative r/d as it will get multiplied many times. So far, the above formula is working ok.
Garrett
Your curve is better. However, note that you are not calculating the resistance coefficient K. You are calculating K/ft (or L/D, since K/ft = L/D) where ft is the fully turbulent flow friction factor. According to Crane, you need to multiply K/ft (or L/D) by ft to get K.
Good job!
