NX5 assemblies
NX5 assemblies
What would cause some assembly constraints not to get loaded when the assembly model is opened up?
I have unchecked "use partial loading" in the load options, but that does not seem to help ... maybe I will see what happens tomorrow.
RE: NX5 assemblies
You say that they are 'not loaded'. Do you mean that constraints that you expected to be there are missing completely, or they are there but flagged with either a Yellow or Red circle/X symbol?
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
RE: NX5 assemblies
RE: NX5 assemblies
Assuming that you're opening the components fully by turning off the partial loading, then could it be that you loaded the faceted reference sets by default. You could in that case turn the partial loading back on, but open the files with the solid bodies to have your constraints re-activated.
Failing that would you allow that some of the parts may have changed in which case geometry that the constraints depended upon may have been altered in a few cases requiring that you reattach some of the constraints.
Cheers
Hudson
